Yes, (if I read you right) since I don't care where the sticky weights go, so long are they are below the hub cap ledge, I can still achieve the optimum type of balancing by placing them near where crimp-on weight would go, as I now understand things. It may be a matter of using just slightly different amounts of weight, but the effect will be identical, I think; the balancing of the wheel can still be perfect. Thanks for responses.
