Old 05-02-2009, 07:01 PM   #20 (permalink)
theunchosen
If you ruin a good Honda Del Sol I will hunt you down. . .
Now that I've gotten that out of the way, OP.
You're best bet first is to start taking things out you don't use. Stow the seats in your basement/garage(away from mice!) After you've ripped those things out the next bext thing is a trans swap. Most of the time auto and manuals will just switch right in and out. Might want to find someone who has done it recently before to invest.
Your car is probably pretty light as is and reducing even more weight would save you alot of FE. I don't know about weather in your area, but if you need or ever use the awd-4wd leave it in. Replacing it you will see some gains but thats alot of work for small mpgs. . .
