Old 05-02-2009, 10:45 PM   #5 (permalink)
NeilBlanchard
Hi,
A chain would require that everything be more perfectly aligned. Plus, changing the tensioner over may be a very tough thing to do -- don't most chain systems have the long curved "teflon" tensioner; while belts have a spring-loaded pulley? How would you securely anchor the tensioning hardware to the block? As someone already mentioned, chains require lubrication.
What are you trying to accomplish, again?
