Old 05-03-2009, 06:31 PM   #4 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
One of the components that won't like sitting is the battery. Unhook the negative battery terminal, or better, leave it on a trickle charger.
Gasoline only lasts so long. What, 1-3 months? So you need fuel stabilizer if you won't be filling it more often than that.
Also check your tire pressure. It'll drop about as many PSI/month as if you were driving the car every day.
The biggest problem, which was already mentioned, is condensation in the motor oil and everywhere else. Get it hot enough, long enough to boil that off.
