Hey, thanks for the support! Actually, it IS Paul's design, just different caps and no PC board. I don't think I could drill through the copper, because I was able to solder things on by heating the back side of the copper, so as not to put too much heat on the leads.
By the way!!! I just tested it in the car at 48 volts (Car on blocks) and got my speedo up to 60 mph... Yehaw! And the controller didn't even get warm -without the water coolant being hooked up.
Question for Paul: I tried tripling up the FET drivers and they randomly "spazzed" out, so I did my testing with just a single driver. Have you tried parallel-ing the drivers yet?
