I would agree most with using synthetic grease in the bearings. Synthetic is usually rated better for both high and lower temperatures, so as long as you use wheel bearing grease, you won't have to worry about it running out when it gets to operating temperature or if it is a hot day.
Winter daily driver, parked most days right now
Summer daily driver
