Old 05-07-2009, 11:19 PM   #35 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Originally Posted by roflwaffle View Post
Well, I've read a lot about pumps at least.
The main idea though is that wear and thinner fuels almost certainly retard dynamic timing, so increasing internal pump pressure is better than nothing. On a slightly related note, this is also why people with VE pumps on biodiesel may see better or the same mileage even though biodiesel has less energy per gallon. With a more viscous fuel, the advance mechanism works closer to stock spec. Ideally if you can check timing you can compare a change in that to mileage, but even w/o checking it you can still make small changes and see if anything improves, using the normal timing to fine tune.
I don't know if anyone has measured changes in IP pressure to EGTs, but it should help, along with excessive clattering, in determining if you have too much advance.
I had not thought about fuel viscosity changing timing. That introduces another parameter, fuel temperature.
