My first choice would be flush-mount clips. Z-clips would work, but would have to be set at angles to take side loading. The easiest hardware to obtain for hacking might be common shelf brackets and track (K&N?) Anyway, you'd just set the hardware to lock when you push forward on the rack. A couple of screws would keep it from sliding back, and you could just drive them deeper to release the unit.
