should have left the stock injectors in there. unless you bumped the fuel rail pressure up to 49 lbs you are running the injectors with not enough pressure. 96-97 had the highest fuel flow rate in the 43.5lb range 23.5lbs the 93-95 had 22's and the wj's had 22.5. you end up with a 21lbs/hr injector that doesn't atomize as well
