Old 05-10-2009, 11:22 AM   #92 (permalink)
ShadeTreeMech
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Instead of using a chain drive, you might consider using timing belt pulleys. V-belts need a bit of tension and rely only on friction, while the timing belt has the teeth to help with grip. Just thinking a gear reduction using a cam pulley on the motor and the crank pulley on the output would give you a good, reliable, quiet and maintenance free gear reduction and would weigh a bit less. Lots of cruisers use a timing belt arrangement as their main drive.
How much drive capacity you expect to lose without the regen braking?
