Old 05-11-2009, 01:07 PM   #2 (permalink)
Daox
Do you know the transmission code for your car?
The Paseos run a C150 5 speed, and the Tercels run C141 (4 speed), and C150 (5 speed). All parts I believe are interchangeable. The 4 speed has the lowest differential @ 3.526. The only thing is, I'm not 100% sure that the 4 speed differential will fit a 5 speed transmission.
If you run a C5x transmission, you have a much larger gambit of transmissions to choose from as you'll share parts with the Corolla, Matrx, and MR2. However, in this family of transmissions, I know the 4 speed differential does not fit into a 5 speed housing. Still, there are a few transmissions you could take a 3.722 differential from.
