05-12-2009, 03:25 PM
#42 (permalink)
LurkoModding Ecker
Minimum Speed Laws
This is an interesting discussion, it prompted me to look up the law here in arizona.
Originally Posted by Arizona Vehicle Code
28-704. Minimum speed limits; requirement to turn off roadway
A. A person shall not drive a motor vehicle at such a slow speed as to impede or block the normal and reasonable movement of traffic except when reduced speed is necessary for safe operation or in compliance with law.
B. If the director or local authorities within their respective jurisdictions determine on the basis of an engineering and traffic investigation that slow speeds on any part of a highway consistently impede the normal and reasonable movement of traffic, the director or local authority may determine and declare a minimum speed limit below which a person shall not drive a vehicle except when necessary for safe operation or in compliance with law.
C. If a person is driving a vehicle at a speed less than the normal flow of traffic at the particular time and place on a two-lane highway where passing is unsafe, and if five or more vehicles are formed in a line behind the vehicle, the person shall turn the vehicle off the roadway at the nearest place designated as a turnout by signs erected by the director or a local authority, or wherever sufficient area for a safe turnout exists, in order to permit the vehicles following to proceed.
Jacob this one is for you.
Originally Posted by California Vehicle Code
Minimum Speed Law
22400. (a) No person shall drive upon a highway at such a slow speed as to impede or block the normal and reasonable movement of traffic, unless the reduced speed is necessary for safe operation, because of a grade, or in compliance with law.
No person shall bring a vehicle to a complete stop upon a highway so as to impede or block the normal and reasonable movement of traffic unless the stop is necessary for safe operation or in compliance with law.
(b) Whenever the Department of Transportation determines on the basis of an engineering and traffic survey that slow speeds on any part of a state highway consistently impede the normal and reasonable movement of traffic, the department may determine and declare a minimum speed limit below which no person shall drive a vehicle, except when necessary for safe operation or in compliance with law, when appropriate signs giving notice thereof are erected along the part of the highway for which a minimum speed limit is established.
Subdivision (b) of this section shall apply only to vehicles subject to registration.
Amended Ch. 364, Stats. 1979. Effective January 1, 1980.
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong. -Buckminster Fuller
