Old 05-13-2009, 04:52 AM   #25 (permalink)
vtec-e
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Originally Posted by daqcivic View Post
Ollie, interesting that you show such clear results with your GB change. It would seem there is significantly more pressure build-up in recessed areas. How much was your original GB recessed?
I wonder if you would see the temp drop back down if you slightly enlarged your outer GB opening and curved it inward so that the final aperture was the same as your original GB.--how much was your original grill block recessed?
It remains to be seen, however, whether and how much recessed zones at the leading edge actually affect the airflow and increase drag overall.
It was about 2 inches deep. I might leave it like that for now but if i have to do any daytime driving in any kind of heat i'll have to dump heat in the cabin! I need someone to make me an automatic grille block. ......now who could i get?.......
ollie
