Old 05-13-2009, 03:45 PM   #5 (permalink)
wmwinfield
Originally Posted by kitaimdao View Post
Welcome, I want to remove my spoiler, but it'd leak
I understand that. however if you would really like to remove it could do what i did filled the hole with newspaper then took a mesh from a screen door and used fiberglass filler bondo will work to and sand with numerous different grit until you get as smooth as possible prime and repeat. if you dont mind the look of primer. lol
took off alot of weight from my car especially the wiper which you can imagine the weight due to the single wiper across the entire rear window.
