Old 05-13-2009, 11:25 PM   #21 (permalink)
Russ
Lurker is indeed accurate
Just off, the 1951 Chevy Pickup would have a curb weight of 3200lbs or so. I found several different numbers. Looks like some of the hot rodders have put aluminum beds on them for weight savings.
Also most of the older stuff will be rear wheel drive. That has to make things less complicated right? Maybe lets me put a little bit of battery weight on the front axle. An in-bed truck box for weather proof battery storage. It's an interesting idea.
More research clearly needed,
-R
