Oh right, the ringing
That's right on the FM radio band! You could tune in to your controller's ringing!
I have noticed that IGBT's are very often used with a hardcore low-value capacitor across the emitter and collector to prevent ringing. Have you looked into that on this controller? Is it a good or bad idea? I don't know, i'm no power electronics guru. Maybe you can run it by the power expert.
