Old 05-14-2009, 10:42 AM   #1235 (permalink)
MazdaMatt
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
Careful, your R may be .008/10, unless you want to use 10 capacitors. Probably the closer to the leads the better, so you may be right, but you're talking about 100 dollars in caps, then. However, capping here may greatly help the other capacitors and batteries... the whole works, really. Again, i'm talking about a method usually used on IGBT's and I'm no power engineer ( did i mention that?)
