Originally Posted by Formula413
Neil,
Based on my experience driving an xA (you read my review) I think this would be a great mod for FE. However I wonder if using a much taller final drive like a 3.5x would make the car overly sluggish from a standing start due to the 1.5's relative lack of low end torque. Maybe you should test drive an '04 Echo with a 5 speed to get a feel for it before committing to the swap. Also keep in mind that your car is about 300 lbs heavier than the Echo.
My buddy had an 04 Echo hatchback and it seemed to have lots of grunt in 1st and 2nd. We towed about 800-900lbs of fishing boat and trailer and even on the boat launch it did ok. Wind up a little wheelspin and up it went.
At 60mph steady it posted some pretty high mpg numbers on my scangauge, 54-60mpg if I recall right.
Anyways if you find a hatchback to try you might end up just trading in your xA for it...
