Originally Posted by MetroMPG
I'm with Leanburninating: I can't remember the last time I used the clutch to shift to neutral. Light pressure on the shifter as the transmission unloads, and it shifts out of gear like butter. I rarely glide with the clutch in.
Is that better/worse/the same for the clutch? You're not pressing your clutch in which seems like it would be good, but wouldn't it make your tranny more upset (or at least have more of a possibility if you miss your throttle blipping)?
