I have yet to work on an HF or VX, so I may be incorrect but I have strong suspicions that the trans will not roll over into the Del Sol.
Not ragging you at all lol, just I own one. What you can do is drop a "new" salvaged trans from a civic that has taller gears(all of them lol) straight into the bay and bolt it in. Only difference will be gearing.
The overseas Sols have different trans packages than the US and I am pretty sure both JDM and Euro got taller gears. So if you could find one of those and ask you could do that.
The Del sol for those that are unfamiliar is FFW, Front-Front Wheel drive.
I'm pretty confident all the Honda(acura) drive lines that will direct bolt on after the trans are identical. If they have bigger or smaller anything the bolts aren't going to line up. (I'm fairly certain fram having been under a few civic lxs and exs from my sol model year, but I could well be wrong. . .I usually am ^_^).
