Old 05-16-2009, 07:27 AM   #42 (permalink)
AXMonster
British Ecomod Hypermiler
AXMonster's Avatar
The AXe - SOLD - '97 Citroen Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
Foci - '03 Ford Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
Originally Posted by diesel_john View Post
I read about multi-pulse injection, is there gain in efficiency with this technology or is it aimed at emissions?
Its mainly for NVH and emissions John.
Most, if not all, common rail injection systems now employ at least two injections; a pilot injection to initiate combustion a few degrees before the main injection, and the main injection which will deliver the remaining circa 90% of the fuel quantity. This quietens down the main combustion when it is injected as the flame in the combustion chamber does not ignite the fuel with a harsh knock (as it would do if it were to ignite by compression ignition alone).
Newer systems (typically with DPF technology) are capable of up to 3 pilot injections, 1 main injections and 2 post injections!
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
