Old 05-20-2009, 02:35 AM   #65 (permalink)
jyanof
Joe
Originally Posted by ev59rag View Post
What say you?
I'm not sure! Maybe we should try it? I'm headed down the path of a typical power supply buck converter (which i have some progress to update on) and think it's going to be doable. Maybe someone else is up to the task?
Two of my goals are high power (~4 kw) and charge control. High power gives you quicker charge times and (from what i've read) can extend the life of lead acid batteries. Charge control gives you automation and assurance that the batteries are optimally charged for both life cycle and capacity. Also, with an unforgiving chemistry like Lithiums, you must charge it correctly - any mistake can ruin a $15k pack!
Anyway, I think PWM and mosfets are the way to go, so that's where I'm headed...
