Yeah I gotta do this too, as the weather heats up and coolant temps become critical.
Without high-jacking the thread, is the basic premise that you just squeeze an extra wire or pin into the 87 terminal on the coolant fan relays? Extra power draw of an LED is negligible I suppose. Should one fuse the newly tapped wire in case of a short?
