Old 05-22-2009, 01:29 AM   #3 (permalink)
theunchosen
To find a good mechanic who won't rip you off. . .
Find something that will take them at most a minute or two to fix with no additional parts and just a little effort and see if they charge you.
I work in a shop and if its a stuck bolt or switch is stuck(and it takes less than 5 minutes) we usually don't charge. The advantage is it ought to be inexpensive even if they do charge and if they don't you found the right place.
