Old 05-23-2009, 04:05 PM   #22 (permalink)
theunchosen
Oh. . .No grill block. As this is ecomodder and you are having coolant issues I assumed it was one of the myriad grill block problems.
In that case something is probably dysfunctional. Most likely the water pump. If its not that. . .pour water through your radiator with the drain plug uncapped. If its coming out at a slower rate than its going in you've got some blockage.
You can also take all the lines off of things and run water through them. Just be sure to put the plugs back on and reattach the tubing.
