I wouldn't bother with 0W. Stuff pours like water it's so thin and will find places to leak from. Also, the 0W doesn't protect as well at high temps as 5W/30 and is, IMO, unnecessarily overkill low for cold temps. If you were going to change at all, you'd be better off going to 10W/40 for the summer than 0/20, but the 5/30 is probably the best all around choice. What does the owner's manual recommend?
