Old 05-25-2009, 10:03 AM   #387 (permalink)
Mart
A good start is finding what protocol your car support Considering Magister experience, you should rely on multiple sources instead of one I made the same mistake... and usually dealer dont know much as well...
I'd also advise also building the rs-232 interface located here (prj.perquin.com) and try to run freediag and see if you can connect. It will cut debugging time.... since you will do it from a PC...
anyway so far, (after spending countless hours in my damm car) I have been able to communicate with the denso/subaru ECU using another protocol called SSM (Subaru Select Monitor). It is also way faster than KWP2000 and since it is more a performance oriented application, I think I will explore that route and get back to ISO later down the road.
Mart
Originally Posted by Magister View Post
I spent countless hours in my Elantra too, with the scope and all, trying to debug it, when I realized it was CAN instead of ISO, even if Hyundai Canada told me "no sir, your car is not CAN"...
