I would be wary of destroying your pump. . .they are expensive to buy and expensive to replace(usually located in very incovenient places.. .)
Although. . .if you are just running bio and not switching back and forth(adding a little mix to keep it from gelling doesn't count) the stressing on the seals shouldn't be too terrible of a problem though. . .
I'm not much of a diesel guy but if you take a little diesel along as well as water and repeat the test with it it ought not become cloudy or have any precipitates.
If it does there are some derivatives in the fuel and who knows what they do when burned at compression. . .?
