Old 05-25-2009, 11:03 PM   #1417 (permalink)
blackpanther-st
OK that sounds good!
Are there two comparator/nand gates?
One for the hardware over current protection, and one for the microcontroller?
If so then it should be fairly easy to filter after the comparator/nand gate going to the microcontroller. That is if you need to; from what DCB posted it seems to me that you might be able to keep your synchronization as I was asking about before.
"Experience is something you get right after you need it !"
http://www.diyelectriccar.com/garage/cars/143
http://www.diyelectriccar.com/forums...tor-32083.html
