Old 05-26-2009, 01:18 PM   #3 (permalink)
wyatt
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
You could make an actuated grill block, even hand operated from inside the cabin. When the fan comes on, the grill block gets opened, when it turns off, the grill block gets closed. That may cut your 15 seconds of on time down to 5. If you hand operate, you may find a good setting for different speeds and outside temps so the fan never comes on.
