Old 05-26-2009, 04:13 PM   #17 (permalink)
LeanBurninating
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Honda Civic HX
90 day: 44.37 mpg (US)
thanks for the tip!
I would most prefer to have something like this
10 VDC PANEL METER | AllElectronics.com
because... all I have to do is ground it and plug it into the right wire. If I could find a 5 volt meter that would be even better. The only drawback is that there is no backlight. So either I jimmy one up or only use it in daylight.
A digital one is cool, but I would rather not have to supply power to one if it could be avoided, and what if it uses a 9v battery? How can you get 9v to something in the car?
I wish there was an automotive voltmeter that had a range other than 8-18 volts.
Thanks for the help.
