Originally Posted by steiner
Paul/Adam,
If you want, I have a cad program that has an embedded cam program. It allows me to either import or draw a cad file and then generate the necessary g-code to machine it. It also has the ability to drill all of the holes. I would be more than happy to do this and then send the g-code to someone with a cnc machine. My cnc is currently waiting for parts.
If you are interested, I would need either the cad drawing or a hand sketch with dimensions. I would also need to know what diameter cutter you intend to use for the machining and if your machine is 2-axis or 3-axis.
What program is this? If I have it in dxf, I can use Cut2D to do the CAM. Ideally if it were in Eagle then we could use PCB-GCode.
