Old 05-27-2009, 05:54 AM   #9 (permalink)
sepp
sepp's Avatar
the jeep - '02 nissan kingcab
Last 3: 29.07 mpg (US)
is the opening of the wheel well close to flat, or does it bend in 2 dimensions? if its close to flat you may better be using aluminium plates, it's cheaper and they are already flat! chances that you can make something of decent quality out of fiberglass from the first try are close to zero. but obviously once you mastered it somehow, then possibilities of making complex shapes become far greater.
