Old 05-27-2009, 05:35 PM   #17 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
On your car, I believe that the rear tires project beyond the lower edges of the fender, na? Depending on the suspension softness, etc, I'd start to define my new shape by taping blocks about 2cm thick on to the tire, and bending splines smoothy over them to where they meet the body. I'd use a gentle curve, probably going at least 10 cm past the wheel opening in all directions, and much farther near the lower edge. Starting from the bottom, you can work up and make a shape that takes a smooth vertical spline. Where the edge of the skirt meets ridges on the body, you can either use a jagged (coped) edge, or blend the shapes. You want to get a nice-looking edge shape overall by varying the curve in the splines somewhat as you go up.
