Old 05-28-2009, 05:11 PM   #32 (permalink)
stevey_frac
Jalilah - '07 Chevrolet Cobalt LT
90 day: 40.57 mpg (US)
Originally Posted by wyatt View Post
Here is a "simple" method of building fiberglass parts. I think it goes with what bicycle bob had said, but instead of using the wood, you use foam. You can fiberglass over both sides of the foam and have a thick part, or do one side and mechanically (scrape, hack, scratch, sand) remove the foam.
Can I not use the foam as a mold to make many out of?? Or do i have to make a more complicated mold for that? I was planning on making it out of that foam board insulation, glued together. The difficulty would be in removing the plug after the fiberglass had set.
