Old 05-29-2009, 12:51 AM   #1473 (permalink)
steiner
The zip file contains a dxf file, a pdf file, and a g-code file of the power section of the controller with all of the holes. The g-code can be viewed in notepad or any other word processing software. The g-code is currently only for the "top side" of the board. It was done using a Bridgeport EZ-Trak post processor since this is the machine that I have. The (0,0) point is located on the upper left corner of the "top side". All of the tooling paths are for the centerline of the lines shown. My software will let me produce the g-code for 25 other machines. If you let me know what brand of control your machine uses, I will see if I can use the correct post processor for it. I can also set the z-axis plane to whatever you like along with the x-y speeds and the z-speeds.
