Old 05-30-2009, 03:06 PM   #23 (permalink)
Ptero
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Smart Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 BMW V12
90 day: 26.4 mpg (US)
Wildfire 250C - '08 Shandong Pioneer 250C
A real clutch would be ultimately more efficient than a freewheel though since you don't have to use the starter as much and can bump start if you time the traffic obstructions right.
I entirely disagree. Because there is no neutral with a CVT or CC, a real clutch (as compared to a freewheeling sprag clutch) would require the operater to hold the clutch in for the duration of the glide. As I have pointed out in other posts, the throw-out bearing is sealed, without provision for cooling. It is not designed for long periods of operation, which increases the liklihood if failure.
A sprag clutch, on the other hand, allows instantaneous coasting whenever the throttle is backed off. Obviously, a gentle matching to regain drive force will have to be practiced by the operator to prevent damage to the sprag clutch or stressing of drive components. Still, for hypermiling applications, I can think of nothing better.
