Originally Posted by adamj12b
Hey Paul,
A simple way to solder the bus bars to the board would be to add the solder to the board, rub some rosin on the rail and lay it on the the spot to be soldered to and then place it in the hot oven. Keep an eye on it, and take it out carefully when the solder melts. A heat gun would work as well, or heating the buss bar on the grill and then placing it on the solder.
Just thinking out loud. lol
-Adam
I think that your last idea of the grill or even just lay the buss accross the stove top burner should work well. keep in mind that you dont want to get the board it self too hot or it will delaminate; you only want the buss just hot enough to melt the solder.
