Old 05-31-2009, 10:41 AM   #2 (permalink)
grischa
rabbit diesel
hi there
i have a rabbit diesel pickup. it runs, drives, brakes, but needs some attention. 1981, 4 speed. i also have a lot of parts to go with. 5 speed transmission, spare diesel injection pump, a parts truck that is only good for the glass and the dash, tail light, window seals etc. the truck has new timing belt, injectors, glow plugs, fuel filter, front engine seals, washer pump motor, exhaust front to back, good tires. it needs a new battery (i may get that), parking brake cable (i have a brand new one that goes with it, motor mounts (not sure if it needs them, but i have brand new ones. so if you want to change the transmission to the 5 speed, you could do the mounts at the same time). the interior is not great. the body has some rust, but is not falling apart. i have about 2000 $ in to it, but i will take less. need to get rid of it asap. i drove it around like that, but i would consider it a project. for 1500 i will let it go including all parts, parts car, some special tools (dial meter to adjust the pump timing, pump lock pin and little stuff like it), bentley manual and parts catalog. with the 4 speed i got 39 mpg. the 5 speed should to a little better. i am just south of chicago in miller beach. it is a part of gary, but to the east of the city right on the lake. send me a mail if that sounds interesting to you. grischa11@yahoo.com
