Old 06-01-2009, 01:19 PM   #38 (permalink)
DonR
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
LT metric Load Range E tires are rated at 80 PSI. Load Range D is 65 PSI. Load Range C is 50 PSI. The truck was designed to handle the load the tires can take. Most people won't run them that high unless loaded. If the truck is loaded down 80 PSI doesn't ride that bad. Unloaded the contact patch gets mighty small.
Don
