Old 06-02-2009, 02:19 AM   #75 (permalink)
arnolde
Hi,
I use a standard industry 3-phase 400V inverter for a standard industry 400V 3-phase motor :-) 400V times sqrt(2) is 560 so thats the DC voltage on the DC circuit. luckily 500V is sufficient, maybe even 450V would have been enough, but high voltage = low current and higher possible motor rpm.
Thanks a lot for the links, I'll order all the parts today and hopefully tomorrow I can start wiring things up. I cant wait to show all the German smart-asses on the electronics forum how easy it is to do what they say is "impossible for under 2000 EUR" or even "impossible even just to draft a circuit for less than 500 EUR" - harharhar :-) But I owe it to you, I had similar ideas but since you've already proved it will work in principle, that gives me the extra motivation to actually do it. Thanks a lot for the pioneer work!
I hope to get all components from stock. I use rs-components and Farnell for my electronics orders. So even with orders from the USA, it's here in 3 days :-)
You say you "originally had a shunt" for current measurung? What do you use now?
Take a look at this: http://www.st.com/stonline/products/...99/uc3842b.pdf see figure 19 on page 9, looks rather simple to me? Maybe not quite as simple as a 555 circuit but at least its self-regulating!
Consider safety issues with using just a µC for the PWM. Imagine your program locks up (bug in software, or even a hardware problem with the µC, or overheating) and leaves the duty cycle "ON". It will roast your batteries. You need to implement several safety features to prevent that from happening.
