Old 06-03-2009, 01:59 AM   #78 (permalink)
arnolde
Thanks a lot for the literature :-)
Okay I guess a dedicated PWM controller is too complicated (or in fact, too time consuming to read all the design sheets and decide on a design to use) for me right now, too. Since the critical part is the power switching part, I think I'll also use a 555 to start with until I've proven that the whole thing works as I plan. Still nobody seems to beleive I can build a 3000W PSU for under 500 EUR so I'm itching to prove them wrong ;-)
I'll draw up a circuit and order components now. The 2 coils will come from USA (150µH, 30A, 16 EUR each) and the capacitors are also on the expensive side (400V/560µF, almost 10 EUR each)
Say, how do you power your NE555? Seperate battery/PSU or from the high voltage? I think I'll add a little 5$ transformer to provide dual 15V, then I can use a hall sensor too later if necessary.
I think I'll start with 48kHz PWM frequency (3,3k / 10nF)
Say, those transformer like things, are those your 150µH coils? According to the datasheet they should look quite different... http://www.vishay.com/docs/34022/ihv.pdf
