Old 06-05-2009, 05:05 PM   #4 (permalink)
DonR
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I believe the production car CVTs are hydraulically controlled by a computer. The signal that goes to the hydraulic cylinder is probably based on engine RPM, axle RPM, throttle position & possibly change in throttle position. There may be position sensors(lvdt) involved as well. you may be able to adjust a signal going into the computer from one or more of the sensors if the mfr. used seperate engne & tranny cpu's.
I wish you luck.
Don
