Originally Posted by charlie_fd
Keep up the good work! I'm running your software on a test-board, using a pot for throttle and a LED for motor. I've added a bootloader so I can quickly update the uC directly from Avr Studio using the serial link. I'm testing serial communication from within the HighVoltageController.c ...
Did you make your own test board? or are you using a breadboard? if the former, what PCB software did you use? I'm in the process of putting this in Eagle so I can design my own layout and mill it at home.
