Originally Posted by MPaulHolmes
That's awesome Adrian!!! How complete is your control board? Did you use an HIN202CP?
I used a max232. The board is just the brain part. A pot is connected to the pin for throttle, a LED to the output pin so I can see the PWM output. There is no current sensor. It will help me test the communications part until I get the real control board.
