Old 06-13-2009, 02:14 PM   #17 (permalink)
Ptero
Hydrogen Nut
Ptero's Avatar
Smart Car ForTwo Pure - '08 Smart Fortwo Pure stripped
90 day: 51.35 mpg (US)
BMW 750iL V12 - '90 BMW V12
90 day: 26.4 mpg (US)
Wildfire 250C - '08 Shandong Pioneer 250C
If you get popped by a strong sidewind gust,you want the car to weathervane,turning the car into the wind,cancelling the yawing-moment,not pushing the nose around where the side catches even more air,causing you to go out of control.
I'd put tractor brakes and yaw props on it, but with Craig's tail it will just blow off the highway and I won't have to worry about weathervaning. The thing I like best about it is that if I ever build the rigid dirigible I've always wanted, I can use it as the control car and then, after I've moored, I can release the clamps from the roofrack and drive into Lakehurst. Hey, I can use the tail as a rudder!
Seriously, I will post the weights when I start work.
