Old 06-14-2009, 08:18 PM   #1700 (permalink)
Cyruscosmo
Hey Paul
A question about the throttle pot does it have to be a 0 to 5k pot or could I use a 1k to 5k range TPS from an EFI system?
The reason I ask is that I have a couple old 350 chevy truck TB’s laying around that already have a place to hook a throttle cable with idle adjuster (which is used to set the TPS to 1.0K) range limiter, return spring and TPS all in one. It would make hooking the unit up to a throttle cable so much easier.
Cyrus
