Old 06-15-2009, 12:26 AM   #43 (permalink)
Istas
is not covered in bees.
Istas's Avatar
Honda - '05 Honda Accord EX
90 day: 27.16 mpg (US)
Insight - '00 Honda Insight w A/C
90 day: 66.55 mpg (US)
Send a message via AIM to Istas
Starting the grille block!
I only got the passenger side of the lower partial grille block done so far, but I have the sheet metal cut out for the other side and the middle-and-upper grille block. Hopefully all the main one will require now is some bending and finagling to get it into place.
Here's some pics of the lower part I did get done.
The other side will look the same. I'm going to work on putting some ducting in on the sides there so there's less of a lip for the air to travel over. I don't think I'll be able to seal the whole passage from there to the radiator, but I'll do what I can.
