Originally Posted by charlie_fd
If other people would like to test the serial link, I've uploaded the changes in the r16 on svn. Here are the modifications: Changeset 16 for trunk/HighVoltageController.c - Open ReVolt - Trac
For testing conect a null modem cable to your pc and receive at 19200baud with 8n1. Any java programmer outthere wants to make the client for this?
Ups! I had commented out the HighPedalLockout ... Restored it in r17.
I've put a little java client together that will monitor the serial port based on the above code. I could probably add a little more to log the data to a file in csv format.
As the code above only seems to transmit the current draw.....
since I don't have an Atmega, I wrote up some PIC code to perform essentially the same thing in order to test the Java code
I am by no means an expert programmer......but your welcome to it if it helps the cause.
