Well, no... But it wouldn't hurt to have a spare set, if you can get them with it.
Basically, I mean the complete "stick". The gear housing (pumpkin), the axles, the axle tubes, and hubs, including the brakes and drums.
You don't need the leaf springs or shocks, and you should have the brake lines from each side to the junction point near the middle of the "stick". Basically, everything between the wheels, but nothing else is needed.
